KinCony ALR ESP32 I/O pin define
ANALOG_A1  4
ANALOG_A2  6
ANALOG_A3  5
ANALOG_A4  7
1-wire: 15
digital input:16
DIP switch: use for set LoRa address
DIP-K1:47
DIP-K2:21
DIP-K3:14
DIP-K4:13
DIP-K5:12
DIP-K6:11
DIP-K7:10
DIP-K8:9
relay:48
IIC SDA:39
IIC SCL:38
SPI_Bus: (For SX1278 LoRA)
CS: 41
MOSI: 44
MISO: 43
SCK: 42
RST:2
DIO0:40
is the button DL the DIO0:40?
DL button is GPIO0
THis is correct & tested
#define IO0 0 //DL Button
all kincony's esp32 board , DL button use by GPIO0
Hello admin,
I am using the KinCony KC868-A6v3 board and developing custom firmware with Arduino / PlatformIO.
The SSD1306 OLED works with the factory firmware, but when I upload my own firmware the LCD stays blank.
Could you please tell me:
What GPIO pins are used for the OLED I2C (SDA / SCL)?
What is the I2C address (0x3C or 0x3D)?
Do we need to initialize any IO expander or controller before using the OLED?
Do you have a simple Arduino example to initialize the onboard OLED?
Thank you.
already replied in another topic.
