01-30-2026, 06:55 AM
Hi everyone,
I am building a lighting control system for about 170 mini incandescent bulbs.
Load
I plan to use multiple Kincony KC868-A32M (32-channel MOSFET output controllers) to get enough channels.
Wiring Idea
I want to use a common +6V bus and low-side MOSFET switching:
All controllers and the 6V supply will share a common ground.
Questions
Load
- Bulbs: 6V, 0.2A each
- Total: ~170 bulbs
Wiring Idea
+6V bus → bulb → MOSFET output → GNDQuestions
- Is this the correct wiring method for KC868-A32M outputs?
- Can these MOSFET channels support PWM dimming for incandescent bulbs, or only ON/OFF?
- What is the best way to control multiple KC868-A32M boards from a PC (LAN/MQTT/Modbus)?
- Any important power or wiring concerns for a 170-bulb system?
