T32M issue with Output 1
I have just received my T32M device and started assembly. I noticed that Output 1 is directly connected to DC+, turning on/off the output doesn't stop the circuit, it's always on.
I have recorded a short video to demo. Can you please advise if there is something special about output 1 or if there is a fault? All other outputs from 2 to 32 are ok, can turn them on and off.
T32M Output 1 problem
can you connect with a load, such as a extend relay or DC contactor, test if work well. if also have this issue, tell us your order number, we will re send you a new T32M controller, maybe need replace the mosfet of OUTPUT1 port.
(02-22-2026, 12:08 AM)admin Wrote: can you connect with a load, such as a extend relay or DC contactor, test if work well. if also have this issue, tell us your order number, we will re send you a new T32M controller, maybe need replace the mosfet of OUTPUT1 port.
If I connect a load to this output it always stays on. I purchased the controller through your "Kincony Controller Store" on Aliexpress, I have messaged there.
ok, i see. that is not our official store, it's our agent. your board need replace mosfet for OUTPUT1. if you can replace , you can try . if you can't replace, contact with the seller.
Hey everyone, I've got a quick question about a video demo I just recorded. I'm seeing something odd with output 1 and wanted to get your thoughts.
(05-06-2026, 06:49 AM)BarbaraVikuvis Wrote: I have recorded a short video to demo. Can you please advise if there is something special about output 1 or if there is a fault? All other outputs from 2 to 32 are ok, can turn them on and off.
Hi Barbara, from the earlier replies it looks like Output 1 isn’t supposed to behave differently from the other outputs. If it stays on even when switched off and a load confirms the same behavior, it sounds more like a MOSFET issue than a configuration problem.
I’d probably contact the seller first, especially if the board is still under warranty. Hopefully they can arrange a replacement or advise on the repair without having to modify the board yourself.
