KC868-A32 - TCP comunication problem
Good morning
I had to replace my kc868-H32B board (which worked for more than 4 years without problems) with the new kc868-32 board. The problem is that when I press the inputs a few times or turn the outputs on and off, the board loses connection (I observe this from the board's web server). The installed firmware is v2.2.14, and only the TCP server is active.
I had already reported this problem in the past with the kc868-a8 board and it seemed to be resolved, but that one also used to freeze often.
I can't understand where the problem is.
Do you have any suggestions or software to test this problem?
Thank you
if you using KC868-A32 or KC868-A8, please download newest firmware: https://www.kincony.com/forum/showthread.php?tid=9814
(10-14-2026, 10:30 AM)admin Wrote: if you using KC868-A32 or KC868-A8, please download newest firmware: https://www.kincony.com/forum/showthread.php?tid=9814
Hello
nothing has changed after updating the firmware.
Unfortunately, since I use it to manage the inside of my house, the problem is very annoying.
Do you have any suggestions for me?
what board model you are using? take a photo. if you can take a video of your problem is better. you can send to whatsapp number: +86-15381188302
(10-15-2026, 11:11 PM)admin Wrote: what board model you are using? take a photo. if you can take a video of your problem is better. you can send to whatsapp number: +86-15381188302
Hi, thank you for your fast reply as usual
Right now I can't send videos because I'm out.
I'd like to know one thing, if it's possible:
I think to understood that the problem is due to the speed at which the commands are sent, and this causes the connection to reset or the board to crash.
Why don't the old boards have this problem?
thank you
i need to understand your problem in details firstly.so i need your video.
(10-14-2026, 06:49 AM)Dm81 Wrote: Good morning
Thank you
I’m having a problem logging into Tuya. When I select Protocol -> Tuya, the page goes back to the login page??? I’ve already updated the software to the latest version V2.2.21 and it’s still the same. Everything worked fine for over 2 years before???
clear your web browser cookies or change web browser.
