05-13-2023, 09:04 PM
KC868-D16 dimmer controller with LED driver
05-14-2023, 07:10 AM
sorry, i don't understand your question.
05-15-2023, 12:07 AM
It´s simple, can i control 2 or more inputs with 1 switch? sure, no problem.
you can click "New Reply" , then you can upload photo, click "insert" to topic.
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ I see now, if i need to send a video to ask something it is the same procedure? Tks for the attention. Mendonca
05-15-2023, 10:36 AM
yes, you can also upload MP4 file at here. do you means: one 6 gang switch panel, there are 6 buttons, every button can use by different controller's INPUT?
05-16-2023, 01:21 AM
(05-15-2023, 10:36 AM)admin Wrote: yes, you can also upload MP4 file at here. do you means: one 6 gang switch panel, there are 6 buttons, every button can use by different controller's INPUT? I mean, one 6 gang switch panel, but one button in the gang switch will use 3 or 4 inputs. I think it will work normally....
05-16-2023, 01:31 AM
yes, this can work, just use by many dry contact INPUT, no number limit.
05-16-2023, 10:23 PM
(This post was last modified: 05-16-2023, 10:25 PM by mendonca88.)
(05-16-2023, 01:31 AM)admin Wrote: yes, this can work, just use by many dry contact INPUT, no number limit. This is the schematic. The Inputs of the module use the GND or 0V from supply? Tks
05-17-2023, 12:21 AM
INPUT = GND or 0V mean trigger. suggest short with GND.
