Threads: 0
Hello, I have the H32B PRO, HOW CAN I ADD SENSORS?
Threads: 1,531
H32B Pro support use by dry contact sensor, just connect to 6 digital input ports.
Threads: 0
Hi my kc868ak not working. I am able to control my H32BS relay using rs485 through waveshare modbus gateway. But when connected to kc868Ak not working. Please help
Threads: 234
(10-17-2023, 11:33 AM)Nikhil Wrote: (09-30-2023, 11:28 PM)admin Wrote: if you want use use KC868-AK work with KC868-H32BS, need config AK board firstly, here is details:
https://www.kincony.com/how-to-use-kc868...board.html
Done everything as said in document. My H32BS relay works when using waveshare rs485 gateway. But when I tried connecting gateway to 868Ak, i cannot get any data in node red when button is pressed. How to make sure if ak board is ok
H32BS firmware is H32BS_V2.10SP
Does it need update?
I am attaching configuration pics for h32bs and 868ak
Show me your connections about KC868-AK and KC868-H32BS.I want to make sure the connection is OK.
