10-30-2023, 05:37 PM
I noticed there is a question already surrounding analog inputs but this doesn't relate specifically to the E16p Board, is Analog inputs (A01-A04) the same as CH1-CH4?
I have a couple of sensors i am using for water level measuring within a water tank, these run off 12v but the sensor returns values of between 0V-5V depending how full the tank is, the more full the tank the higher the voltage being sent down the signal wire. Is this an acceptable voltage range to be put into the CH1-CH4 (what i believe to be analog inputs) and how would i configure this in home assistant to show the water level based on the voltage just on a simple gauge or graph (5v from the sensor indicates 100% water level and 0v = 0% water 2.5v = 50% etc)
I am currently just using the home assistant config code
with slight adjustments made to get temp and humidity information from an SHT31 sensor using SCL and SDA.
Any help would be appreciated.
kind regards,
Callum
kind regards,
Callum
