Getting started with KC-868AG Pro for blinds control with ESPHome/Home Assistant
Hey everyone.
First off, a lot of what I'm asking will be novice questions here, but I'm a quick learner.
I have a set of automated blinds that are controlled with a remote on 433.92Mhz. I purchased a KC-868AG Pro in order to be able to automate them using Home Assistant. I did check out some material on the device before I bought it, but it seems a lot of it assumed some basic setup had been done before hand and I'm struggling with that. I am a technical person and work in IT, but haven't done much with these kinds of devices. Clear documentation and firmware is not easy to find on KinCony's web site and after spending quite some time, I'm not sure I'm going down the right path.
I have downloaded and installed the CH431SER driver on Windows 11 and the device does get detected when plugged in with USB. From what I understand, the next step is to install the ESPHome firmware for this device. However, I cannot find it. Every page about firmware on this forum I can find doesn't list one for this model and I can't find anything for it on the main web site. As I understand it, I can't join the device to my wi-fi or start programming it without this, so I'm hoping someone can point me in the right direction. In addition, is USB power all this device needs for what I want to do or will I need a separate power adapter? Since it powers on and it reachable over USB alone, I'm assuming that's all I need for my use case but again, it's unclear. I understand that I also need a default YAML file for ESPHome for Home Assistant to recognize the device. Is this the case and if so, is there somewhere I can grab that as well?
Once I get the basics done, I think I can figure things out from there. I'm just at a loss on these beginning steps.
Thanks for your help, I appreciate it!
Getting started with KC-868AG Pro for blinds control with ESPHome/Home Assistant - by Parallax Abstraction - 09-09-2025, 10:54 PM
