Yesterday I received my first Kincony KC868-A32 board and tried to install ESPHome.
I initially used the configuration described in the first post, but I had to make some changes as it was no longer compatible with the new version of ESPHome.
The first operation I performed after saving the configuration was validation, where the following warning was displayed:
INFO ESPHome 2025.8.2
INFO Reading configuration /config/esphome/kc868-a32.yaml...
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Is it possible to change the PIN to avoid the warning?
Is this a warning that can be ignored?
The changes made in the original example are:
1. The platform and Framework
platform: ESP32
To:
friendly_name: KC868-A32
type: esp-idf
version: recommended
2. Added the Wifi (commented in my case because I use Ethernet) and Ethernet configuration and enabled the Web Server to test the configuration:
# Wifi section disabled to use Enthernet
#wifi:
# ssid: !secret wifi_ssid
# password: !secret wifi_password
## Enable fallback hotspot (captive portal) in case wifi connection fails
# ap:
# ssid: "Kc868-A32 Fallback Hotspot"
# password: "GmVxfzYtDqBl"
#captive_portal:
# Ethernet section used instead of Wi-Fi
# Ethernet Example configuration entry (It's possible to use only WIFI or only Ethernet, not both)
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk:
pin: GPIO17
mode: CLK_OUT
phy_addr: 0
manual_ip: # Recommended for router compatibility
static_ip: 192.168.1.183
gateway: 192.168.1.1
subnet: 255.255.255.0
dns1: 8.8.8.8 # DNS primary
dns2: 8.8.4.4 # DNS secondary
# Alternative debug and OTA web server
web_server:
port: 80
version: 2
include_internal: true
3. Changed the attenuation value for the adc from 11db to 12db
- platform: adc
pin: 39
update_interval: 10s
attenuation: 11db
- platform: adc
pin: 34
attenuation: 11db
- platform: adc
pin: 36
attenuation: 11db
- platform: adc
pin: 35
attenuation: 11db
To:
- platform: adc
pin: 39
attenuation: 12db
- platform: adc
pin: 34
attenuation: 12db
- platform: adc
pin: 36
attenuation: 12db
- platform: adc
pin: 35
attenuation: 12db
It might make sense to update the first post with the latest changes to the latest version of ESPHome!
