Need help with configuration of multiple controllers in the same house
#11
Hi admin,
thanks for the answer, I will try what you recommended and update if it worked.
I plan the system to work in a redundant configuration, all the components are connected with ethernet cables and I use IP communication to work in the mqtt configuration using home assistens which is installed on the server.
In addition,
I want the option to allow the system to work in RS485 for a situation where the server does not work or a fault in the ip communication so that it will still be possible to control the relays from the normal switches regardless of the communication or the server
for such a situation you still recommend me to change the AK firmware?
And the best way tondo this is to use RS485 modbus?
if this case, i suggest you download kc868-ak-v1.0.7.bin to KC868-AK, this work without any network, just send command by RS232 and RS485. it not use modbus command, but KC868-H32B use by this kincony private protocol.
(11-28-2024, 10:15 AM)admin Wrote: if this case, i suggest you download  kc868-ak-v1.0.7.bin to KC868-AK, this work without any network, just send command by RS232 and RS485. it not use modbus command, but KC868-H32B use by this kincony private protocol.
1. Could you please add a link to the details and documentation of the kincony private protocol
2.The KC868-Server  support the kincony private protocol like the KC868-AK, or i need to chenge the firmware?
3. The KC868-AIO ESP32  support the kincony private protocol like the KC868-AK, or i need to chenge the firmware?
1. kincony private protocol, just STRING protocol, here is protocol document: https://www.kincony.com/forum/showthread.php?tid=3104
2. KC868-Server already include 16+8 digital input ports on PCB, i think you not need to add KC868-AK. if you MUST want add KC868-AK, sure, it's OK, can work with KC868-Server.
3. Yes, support.
Hello admin,
maybe I didn't explain my scenario. I have 2 H32B PEO controllers in 2 separate electrical panels, each in a different panel and I have a KC868-AK to which the switches are connected. All components are connected via RS-485. I did not find a way to set S1-S10 in the KC868 -AK will turn on relays 1-10 on the first H32BPRO located in electrical panel 1 and that S20-S30 in the KC868-AK will turn on the relays 20-30 in the second H32BPRO which is in the electrical panel 2 You can get an example of how to write this command in the most correct way and which protocol is most suitable to use
1. set two H32B Pro with different RS485 address in webpage.
2. download KCS v2 firmware to KC868-AK.
3. create IFTTT, let S1-S10 output modbus command to control first H32B Pro.
4. create IFTTT, let S20-S30 output modbus command to control second H32B Pro.
RS485 modbus protocol see here: https://www.kincony.com/download/KC868-H...Modbus.pdf
if you really don't know how to do. next week when i have free time, have a look, maybe make a video tour. This week very busy.
Dear admin,
thanks for the answer, I'll try and update regardless. I think this is a very common scenario, so it's important that you do a video tour of it.
A question about kc868 server. I connected the switches to the dry contacts that are on the server. Is there a way to set that by pressing switch number 1, relay 1 and relay 2 are turnd on together .i see It's possible in double-click mode, I'd like to set it up with a single click
when have free time , make a video tour.
"single click" can't define actions by yourself. if you use home assistant software, you can set "single click" for different actions.
3 Guest(s)
