Esphome invalid config KC-868 A8
In KC-868 A8 in EspHome I have problems setting up the switch component.
I want that when I press digital Input#1 then relay #1 Toggles.
PCF8574 I/O Expander uses I2C Bus to set IDs, probably that is why the YAML validator don't recognizes the ID of light1? I don't know.
I know I can link the inputs and the relays in HomeAssistant, but I want the logic to be coded in the board so It still works if Internet brokes.
I also know that KCS firmware allows that requirement, but I am looking for an EspHome solution.
Thank you
EspHome Config:
  platform: ESP32
  sda: 4
  scl: 5
ota:
  - platform: esphome
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  - id: 'out'  # for output channel 1-8
    address: 0x24
  - id: 'in'  # for input channel 1-8
    address: 0x22
      pcf8574: out
      mode: OUTPUT
      pcf8574: in
    on_press:
      then:
        - switch.toggle: light1
Yaml Validator Output:
you should add "id" option, here is sample code for KC868-A8S, but the INPUT trigger OUTPUT as same way.
  platform: ESP32
remote_receiver:
  pin: 16
  dump:
    - rc_switch
  tolerance: 50%
  filter: 250us
  idle: 2ms
  buffer_size: 2kb
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
    address: 0x24
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
    interlock: [relay6]
      number: 4
      mode: OUTPUT
    interlock: [relay5]
      number: 5
      mode: OUTPUT
    interlock: [relay8]
      number: 6
      mode: OUTPUT
    interlock: [relay7]
      number: 7
      mode: OUTPUT
    on_press:
      then:
      pcf8574: pcf8574_hub_in_1
    on_press:
      then:
        - switch.toggle: light2
    on_press:
      then:
        - switch.toggle: light3
    on_press:
      then:
        - switch.toggle: light4
    on_press:
      then:
        - switch.toggle: relay5
      number: 4
    on_press:
      then:
        - switch.toggle: relay6
      number: 5
    on_press:
      then:
        - switch.toggle: relay7
      number: 6
    on_press:
      then:
        - switch.toggle: relay8
      number: 7
  - platform: remote_receiver
    rc_switch_raw:
      code: '001111010111001010111000'
      protocol: 1
    on_press:
      then:
    filters:
      - delayed_off: 200ms
    rc_switch_raw:
      code: '001111010111001010111100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110100'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010111001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110010'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110101'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110001'
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      code: '001111010111001010110011'
      protocol: 1
    on_press:
      then:
    filters:
    pin: 14
    device_class: motion
    on_release:
       - script.execute: motion_timer
script:
  - id: motion_timer
    mode: restart
    then:
      - delay: 10s
      - switch.turn_off: light1
      - switch.turn_off: light2
      - switch.turn_off: light3
      - switch.turn_off: light4
(12-09-2024, 10:20 PM)admin Wrote: you should add "id" option, here is sample code for KC868-A8S, but the INPUT trigger OUTPUT as same way.
  platform: ESP32
remote_receiver:
  pin: 16
  dump:
    - rc_switch
  tolerance: 50%
  filter: 250us
  idle: 2ms
  buffer_size: 2kb
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
    address: 0x24
    address: 0x22
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
    interlock: [relay6]
      number: 4
      mode: OUTPUT
    interlock: [relay5]
      number: 5
      mode: OUTPUT
    interlock: [relay8]
      number: 6
      mode: OUTPUT
    interlock: [relay7]
      number: 7
      mode: OUTPUT
    on_press:
      then:
    on_press:
      then:
    on_press:
      then:
    on_press:
      then:
    on_press:
      then:
      number: 4
    on_press:
      then:
      number: 5
    on_press:
      then:
      number: 6
    on_press:
      then:
      number: 7
    rc_switch_raw:
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      protocol: 1
    on_press:
      then:
    filters:
    rc_switch_raw:
      protocol: 1
    on_press:
      then:
    filters:
    pin: 14
    on_release:
script:
  - id: motion_timer
    mode: restart
    then:
      - delay: 10s
Thank you,
I just discovered it and came here to publish the answer, in case someone finds it usefull this worked for me:
      pcf8574: out
      mode: OUTPUT
      pcf8574: in
    on_click:
      min_length: 50ms
      max_length: 350ms
      then:
        - lambda: |-
            id(relay1).toggle();
ok, good.
Can I configure 868 server via mqtt to toggle specific output ?
Example:
switch output 3 - toggle
Switch output 2 - on/of
I have at the moment configuration with on/of but I would like to toggle some output switches.
sure, it's ok.
Can you help with a hint of how to do that?
1. config KC868-Server's digital input ports work as BINARY SENSOR in home assistant by MQTT.
2. create AUTOMATION in home assistant set the ACTION for ON/OFF/TOGGLE.
I have a bug in the KC-868 A8.
Bug description:
   - The board works fine for approximately 20 minutes, then It reboots.
Running EspHome Configuration:
  platform: ESP32
ota:
  - platform: esphome
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  sda: 4
  scl: 5
  - id: 'out'
    address: 0x24
  - id: 'in'
    address: 0x22
      pcf8574: out
      mode: OUTPUT
      pcf8574: out
      mode: OUTPUT
      pcf8574: out
      mode: OUTPUT
      pcf8574: out
      mode: OUTPUT
      pcf8574: out
      number: 4
      mode: OUTPUT
      pcf8574: out
      number: 5
      mode: OUTPUT
      pcf8574: out
      number: 6
      mode: OUTPUT
      pcf8574: out
      number: 7
      mode: OUTPUT
      pcf8574: in
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
        - switch.toggle: relay1
      pcf8574: in
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
        - switch.toggle: relay2
      pcf8574: in
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
        - switch.toggle: relay3
      pcf8574: in
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
        - switch.toggle: relay4
      pcf8574: in
      number: 4
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
      pcf8574: in
      number: 5
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
      pcf8574: in
      number: 6
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
      pcf8574: in
      number: 7
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
      number: 32
      number: 33
web_server:
  version: 2
  port: 80
Outcome:
   - I have 16 lights in my apartment that are controlled with 2 KC-868 A8 boards. After approximately 20 minutes both boards reboot and all lights switch off, then I have to press the switches on again to have light.
Steps I tried:
   - Review the EspHome config file.   I don't see anything strange, Probably I am using a non recommended gpio that makes the trouble?
   - Power supply review, I changed the power supply and connected to different sources but the problem persists. Is strange that both boards reboot at the same exact moment...
I appreciate some expert advice. Thanks
i suggest you download our KCS v2 firmware for a testing. just to check whether the software problem or hardware problem.
