RS485 ON A16
Hello everyone,
I recently bought a Kincony A16 card with the aim of making it work in RS485 with this Waveshare gateway :
https://www.amazon.fr/dp/B09LQMH2S1?ref=...title&th=1
I control this gateway from a Loxone Miniserver, however I can't really understand the Kincony Modbus register table :
https://kincony.com/forum/attachment.php?aid=2240
The loxone page for modbus communication :
https://www.loxone.com/frfr/kb/communication-modbus/
RS485 transmission is enabled in the A16 and gateway parameters.
I need the I/O address and the register type.
Could someone tell me the requests to send to enable / disable an output and get state of digital / analog input on A16 please ?
Thanks in advance for your help, Tom
here is KCS firmware modbus protocol document: https://www.kincony.com/forum/showthread.php?tid=2528
the register address begin with 0, you can check with protocol.
if you integrate to Loxone Miniserver, suggest use our new controller F16 or B16M, it's very easy for integration by UDP command, they support KCS v3.
here is Loxone integration online guide: https://www.kincony.com/forum/showthread.php?tid=7264
Hello, I have been trying to start modbus communication between kincony A16 and EastronSDM630 (https://www.eastroneurope.com/products/v...m630modbus) via rs485 using espHome for some time, according to the documentation the registers are identical to kincony.
Log file shows: [17:53:08][D][modbus_controller:040]: Modbus command to device=1 register=0x64 no response received - removed from send queue
I would like to ask if I have something wrong in the .yaml file:
  friendly_name: md01-kc868-a16-GAR
    type: arduino
  encryption:
    key: "************************************"
ota:
  - platform: esphome
    password: "*********************************"
wifi:
  ssid: !secret wifi_ssid
# Optional manual IP
  manual_ip:
    static_ip: 192.168.88.21
    gateway: 192.168.88.1
    subnet: 255.255.255.0
uart:
  tx_pin: 13
  rx_pin: 16
  baud_rate: 9600
  stop_bits: 1
  parity: EVEN
modbus:
  uart_id: mod_bus
modbus_controller:
  - id: a24
    address: 0x01
    modbus_id: modbus1
    setup_priority: -10
    update_interval: 5s
  - platform: modbus_controller
    modbus_controller_id: a24
    register_type: holding
    address: 0x64
    unit_of_measurement: "V"
    value_type: FP32
    accuracy_decimals: 2
I have been trying to start modbus communication between KinCony A16 and Eastron SDM630 (https://www.eastroneurope.com/products/v...m630modbus) via rs485 using espHome for some time, according to the documentation the registers are identical to KinCony Energy Meter RS485 Modbus RTU Monitor
Log shows me: [17:53:08][D][modbus_controller:040]: Modbus command to device=1 register=0x64 no response received - removed from send queue
    type: arduino
  encryption:
ota:
  - platform: esphome
wifi:
  manual_ip:
uart:
  tx_pin: 13
  rx_pin: 16
  baud_rate: 9600
  stop_bits: 1
  parity: EVEN
modbus:
  uart_id: mod_bus
modbus_controller:
  - id: a24
    address: 0x01
    modbus_id: modbus1
    setup_priority: -10
    update_interval: 5s
    address: 0x64
    value_type: FP32
don't post one questions multi times, your question already repied in another thread.
