01-20-2025, 09:03 PM
hi, i would be interested in using kc868 M16-V2 with home assistant. but i would need to know the power of each channel (and not the current) can the board calculate it for each channel?
kc868 M16-V2
01-20-2025, 11:28 PM
sure, M16v2 can read CURRENT and VOLTAGE. you can set the POWER=CURENT * VOLTAGE in home assistant.
01-23-2025, 06:10 AM
Well! Which calipers would be best to use for greater precision? V or mA?
I would also need to carry some pliers at a distance of about 20 metres, is this a problem?
01-24-2025, 02:07 AM
use mA or V according to your CT clamp sensor type.
01-25-2025, 04:54 PM
ok, but is it a problem for a distance of 20 meters? does the reading remain accurate?
01-26-2025, 01:09 AM
20 meter for CT clamp sensor is no problem.
01-26-2025, 08:22 AM
well, I just placed the order on the kincony website. I hope to be able to work well on homeassistant; )
01-26-2025, 12:22 PM
ok, after china new year holidays, we will send it.
01-26-2025, 09:59 PM
perfect, thanks!
03-14-2025, 01:51 PM
(This post was last modified: 03-14-2025, 01:59 PM by davidemarino33@gmail.com.)
Hello everyone, I am new to the esphome world. I purchased a Kc868 m16 v2 card, who could help me I have difficulty configuring it on home assistant. thanks
(03-14-2025, 01:51 PM)davidemarino33@gmail.com Wrote: Hello everyone, I am new to the esphome world. I purchased a Kc868 m16 v2 card, who could help me I have difficulty configuring it on home assistant. thanks I copied the 3 files into the esphome folder, but when I go to install the yaml file I get an error. |
| 1 Guest(s) |
