(02-04-2025, 12:18 AM)admin Wrote: the default firmware in esp32 is manufacturer's test firmware. Because different people will chose different solution to use. some people config by esphome, some download KCS firmware, some write own arduino code.
if you don't know how to download KCS firmware, you can add whatsapp number: +86-15381188302 we use ANYDESK software remote control your computer to help you.
I do know how to download KCS firmware, thanks. I just can't get it to work like it's supposed to work.
This is how I've configured my temporary LAN: I changed the IP address on my laptop to 192.168.1.14 then connected it to a spare router configured to to 192.168.1.1. and connected the KC868-A16 to the router. When I run the flash_download_tool from my Windows GUI it results in the error as described previously.
I've had to create a separate LAN from my main network because it is set up to 192.168.0.xxx. This is how I've configured my temporary LAN: I changed the IP address on my laptop to 192.168.1.14 then connected it to a spare router configured to 192.168.1.1. and connected the KC868-A16 to the router. When I run the flash_download_tool from my Windows GUI it results in the error as described previously.
It's probably me doing something wrong. I'm finding the whole process rather complicated but I consider myself to be fairly technical. Any help you can provide would be much appreciated.
