Product suggestion: bus bar
as discussed in another thread, it would be very convenient to have for each board a busbar available to connect the terminal of multiple switches and power several of them with a single wire.
Have a look starting 1:05 here for an example from Finder:
https://www.youtube.com/watch?v=RFWGtsfI2NY
do you means this one?
https://shop.kincony.com/products/short-...ctor-brass
it use for every output's COM port.
I mean exactly this Smile I don't know how I missed it, as I already searched for it.
Can you remove (cut) individual connectors from it?
Just use scissors
Hello, what is the max current (A) for these? Do they fit the terminals for H32N-Pro? Thank you!
which terminal? you can confirm with the store seller what MAX current (A). H32B Pro relay MAX for AC220V 7A. usually not use >4A.
Sorry, my question was not clear.
For this product: https://shop.kincony.com/products/short-...ctor-brass
- what is the maximum current?
- can it be used with a HB32B Pro?
Thank you
sure, it's ok use for H32B Pro.
Hello, do you have busbars that fit the terminals of the F8 or F24 boards?
yes, we have , just have not uploaded on our online shop.
