01-14-2025, 10:54 AM
Using 12v on Digital Input
01-14-2025, 11:43 AM
chip type=ESP32 you can try to replace new USB-C cable.
03-07-2025, 07:06 PM
(01-05-2025, 01:12 AM)admin Wrote: input 12v dc = logical "0" means: NOT trigger. but in this way, also if the input is in the air it gives us a 0, it only gives us a 1 when we join it with GND. Is there any way to make the inputs 24V? Or some other type of card? Thanks
03-08-2025, 04:02 AM
KC868-A16 also support DC24v power supply, the digital input also can use for 24v.
03-08-2025, 07:34 PM
How do I have to connect the inputs? where is GND I always have to put GND if it does not short circuit, and the inputs if I leave them unconnected is the same as if I put them at 24v? a 0.
they get a 1 with GND. So I can not use it as PNP as it says in the specifications. Thank you. If you can help me?
03-09-2025, 01:05 AM
input short with GND, that means logical "true".
if you connect with 24v to INPUT, that mean logical "false". so 0v and 24v are different logical state.
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (03-09-2025, 01:05 AM)administración Wrote: Entrada corta con GND, eso significa "verdadero" lógico. Sí, son estados lógicos diferentes, pero no es PNP, solo puedes usar NPN, ¡lo cual está bien! Pero en la mayor parte de la industria en Europa se usa PNP. Gracias por la aclaración. (03-09-2025, 01:05 AM)admin Wrote: input short with GND, that means logical "true". yes they are different logic states, but it is not PNP, you can only use NPN, which is fine!!! but for most of the industry in europe PNP is used. thanks for the clarification.
03-09-2025, 01:31 PM
in KCS firmware, "INPUT" webpage can "invert" the logical.
03-17-2025, 04:39 PM
I am programming it in the Arduino ide
03-18-2025, 12:29 AM
you can also define INPUT with "invert" in arduino code. it's just a software code problem.
| 1 Guest(s) |
