b16m programing blinds
I need help
How di I program the controller to control the blind motor?
For example
If I press the up button once, the motor rotates to the end switsh, i.e. for a certaim mumber of secends, if I hold the same switch, the motor rotates "up" for as long as I hold  it, when I release it the motor stops.
The same procedure for lowering.
but if the button for lowering the blinds is pressed, then all the signals from digital input 1 stop
button for rising  is digital input 1, button for lowering is digital input 2
upload your IFTTT setting screen photo.
Will that be enough for IFTTT?
I don't understand what exactly you need from IFTTT. Big Grin
how many IFTTT command about your motor you have creaed? sorry, i can see only English language.
upload all your IFTTT command setting screen photo.
because now i don't understand your words "but if the button for lowering the blinds is pressed, then all the signals from digital input 1 stop
button for rising is digital input 1, button for lowering is digital input 2".
Digital input 1=raise blinds
Digital input 2=lowering blinds
By pressing DI1, the blinds are raised, for example, for 15 seconds
By pressing DI2, the blinds are lowered, for example, for 15 seconds
If DI1/DI2 is pressed during the lowering/raising operation, the motor stops
By pressing and holding DI1, the blinds are raised as long as DI1 is pressed, releasing the motor stops
By pressing and holding DI2, the blinds are lowered as long as DI2 is pressed, releasing the motor stops
Can you help me with an example of how to handle this situation, not currently related to IFTTT?
I am also sending an example of a schematic connection
it's not easy use so many condition at the same time. you can use 1-click action or hold on action.
"If DI1/DI2 is pressed during the lowering/raising operation, the motor stops. " it's not easy.
i suggest use INTERLOCK mode for two relay. DI1 pressed for raise, DI2 pressed for low.
or you can use if DI1 true relay ON, if DI1 false relay OFF, this for jog.
Can you help me how to use firmware for b16m and INTERLOCK mode, I found your post on youtube but when I login I don't have the interlock option. And can I install more firmware on b16m?
on the "OUTPUT" webpage , there are INTERLOCK option.
[Image: output-webpage.png]
Ok I managed to solve the problem. next question.
how can I pair two b16m to communicate, for example, input DI1 on b16m#1 controls digital output 3 on b16m#2
sure, you can define customize protocol in IFTTT. first controller send TCP,UDP or HTTP command to second controller.
