Temperature is not send to Loxone
Hello, over the weekend, I got the T16M module up and running, and I was able to establish communication with my second-generation Loxone miniserver without any problems. Using UDP, I am able to read the on/off states of the DO, etc.
The only thing that isn't working, and I don't know if I'm doing something wrong, is reading the temperature status. I have a standard DS18B20 1-wire temperature sensor connected to the T16M board, I set the sensor in the board configuration and I can see the temperature(channel 1). Everything works without any problems. However, after setting the virtual input in Loxone, nothing happens. I monitored the UDP monitor in Loxone and no UDP command carrying temperature information reaches Loxone. Only commands for reading/controlling DI and DO. Is this a firmware error? Or does something else need to be set/enabled in the configuration for the temperature to be sent to Loxone?
Just to note, I am using the latest version of KCS3 firmware available right now.
Thank you in advance for your help.
[Image: sensor-webpage.jpg]
do you have set the sensor "Threshold" option? suggest set to 0.1
Thank you, now it works. It didn't occur to me that there could be a problem.
ok, good.
