06-28-2025, 10:16 PM
I am trying to integrate the KC868 server 16 to add I2C hardware devices. I have done step 2
2. enable i2c for home assistant.
Add files to enable I2C
In the root of the hassos-boot partition, add a new folder called CONFIG.
In the CONFIG folder, add another new folder called modules.
Inside the modules folder add a text file called rpi-i2c.conf with the following content:
i2c-dev
In the root of the hassos-boot partition, edit the file called config.txt add two lines to it:
dtparam=i2c_vc=on
dtparam=i2c_arm=on
but i2c devices are not showing. See attached screenshot
i2c-dev
dtparam=i2c_vc=on
dtparam=i2c_arm=on
