When D1 input is pulled low, the input symbol i the web interface turns green, but the D1 output does not respond. The input push-switches does not do anything. In IFTTT i have: IF DI1 single click, THEN DO 1 ON. When i click RUN, it works fine, but not when i pull DI1 input low og push the DI1 switch. I run firmware version KCS_KC868_E16P_V2.2.14
No output DO1-DO16
09-01-2025, 12:11 AM
1: please chose "Raise edge" for "triggle type".
2: after save ifttt, reboot your board.
09-01-2025, 03:01 AM
Rising Edge worked fine, thank you
| 1 Guest(s) |
