Kincony AS
#11
use this arduino code to test your microphone hardware whether is well.
https://www.kincony.com/forum/showthread.php?tid=6897
(09-06-2025, 01:24 AM)admin Wrote: use this arduino code to test your microphone hardware whether is well.
I successfully compiled and uploaded the Arduino code. When I attempted to flash the AS with the bin file after setting the parameters and clicking Start, no response was received; it simply idled. So, the process was not complete, and I could not carry out the mic test. What went wrong? See attached picture
arduino code whether run well? when have sound, serial port output different numbers.
(09-07-2025, 04:51 AM)admin Wrote: arduino code whether run well? when have sound, serial port output different numbers.
Arduino code ran well, but no output on the Serial port, see photo
where you bought from, if microphone is broken, we will re send you a new AS. Tell us your order number, whether bought from kincony official store?
(09-07-2025, 12:19 PM)admin Wrote: where you bought from, if microphone is broken, we will re send you a new AS. Tell us your order number, whether bought from kincony official store?
We bought four from your store, and the four are behaving the same: Order Number 2557
2557
4pcf of AS all can't work?
(09-08-2025, 02:54 AM)admin Wrote: 4pcf of AS all can't work?
Yes, unfortunately. We noticed that the speakers were out of place, which we have since corrected.
I started over to configure Kincony AS, but was unsuccessful. I have attached all the pictures of my configuration. The Wake Word appears unavailable. Kindly debug this issue as I have used three different HA installation with the same result. I bought four of these device. Kindly consider resolving this urgently.
check your home assistant setting.
[Image: attachment.php?aid=8471]
[Image: attachment.php?aid=8470]
[Image: attachment.php?aid=8472]
[Image: attachment.php?aid=8473]
[Image: attachment.php?aid=8474]
newest yaml file download at here: https://www.kincony.com/forum/showthread...904&page=2
