Kc868-A8 and short time for relay
Hello everybody!
I'm super happy with my Kincony so far. I don't have a lot of exp. and this is a reason why I would like to ask you here.
My case: I have bistable relays - two tracks connect to my lights. Switch on the wall is a ring switch. Press and turn on light. Switch back to first position, but relay is set like ON.
I would like to connect Kincony output/relay parallel to that wall switch. But I can not leave Kincony relay closed longer than 1 sec. Why? Because my Schneider relay will be hot after some minutes.
Question: is it possible to configure the relay with a momentary switch action?
Scenario: I click in the app and relay will turn on the light (same like wall switch). Next click on the wall or in the app will turn off the ligh. But question if Kincony will see the state of the light?
Im guessing not out of the box. Because Schneider has two tracks, potentially I could check/probe a state of that in Ardiuno or even somehow in Kincony.
What do you think? What could be the best solution for me?
Thank you for help!
Rafal
let your wall switch (momentary switch) connect to kincony controller's digital input ports. set by IFTTT webpage, INPUT toggle relay output. just download KCS firmware by usb-c cable.
