GPIO numbers for Weigand
I am finding the documentation for GPIO numbers a bit confusing.
Am I correct :
HT1 = GPIO1
HT2 = GPIO2
HT3 = GPIO3
Am I correct :
P39 = GPIO39
P40 = GPIO40
P41 = GPIO41
Finally, Can any of these pins be assigned for TX/RX for D0/D1 with Weigand Protocol?
Hopefully, this will allow me to configure my entry alarm system.
Many thanks in advance.
Paul
sure, it's ok for wiegand.
(11-20-2025, 11:13 PM)admin Wrote: sure, it's ok for wiegand.
Thank you for your kind response... but I still need an answer please:
Please can you comment about the GPIO numbers - actually I am just guessing.
HT1 = GPIO1
HT2 = GPIO2
HT3 = GPIO3
P39 = GPIO39
P40 = GPIO40
P41 = GPIO41
1. Are these GPIO correct ?
2. Can any of these GPIO be assigned for TX/RX for D0/D1 ?
3. To help other customers, please can you provide GPIO numbering documentation for KC868-A16v3 ?
Thank you,
Paul
Can anyone help answer the questions ?
Many thanks
Paul
1-wire (pull-up resistance on PCB):
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO38
free GPIOs (without pull-up resistance on PCB):
free gpio-1:GPIO39
free gpio-2:GPIO40
all esp32 pin define at here: https://www.kincony.com/forum/showthread.php?tid=7614
free gpio-3:GPIO41
For anyone else that needs the correct GPIO for this board... see:
https://www.kincony.com/forum/showthread...&pid=21118
The important image is:
I would like to know what the best GPIO for Weigand...
now I understand the location and PGIO numbering
Thanks.
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO38
showed in your RED section. just GPIO-1, GPIO-2, GPIO-3.
GPIO-1=GPIO47
GPIO-2=GPIO48
GPIO-3=GPIO38
(11-22-2025, 12:48 PM)admin Wrote: 1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO38
GPIO-1=GPIO47
GPIO-2=GPIO48
GPIO-3=GPIO38
This makes sense now...
ESPhome has code:
      number: 47
      number: 48
      number: 38
      number: 39
      number: 40
      number: 41
So, for Weigand we use
wiegand:
  - id: mykeypad
    d0: GPIO47
    d1: GPIO48
    on_key:
      - lambda: ESP_LOGI("KEY", "received key %d", x);
    on_tag:
      - lambda: ESP_LOGI("TAG", "received tag %s", x.c_str());
    on_raw:
      - lambda: ESP_LOGI("RAW", "received raw %d bits, value %llx", bits, value);
d0: GPIO47
d1: GPIO48
Can you advise this is the best solution for Weigand communication?
Thanks,
Paul
you can config wiegand by ESPHome, we also will update new KCS v3 firmware to support wiegand.
(11-22-2025, 11:55 PM)admin Wrote: you can config wiegand by ESPHome, we also will update new KCS v3 firmware to support wiegand.
Hi
I am a beginner with wiegand and ESPHome. I understand how to install wiegand ESPHome - this looks quite easy.
Please can you advise: If I install wiegand ESPHome ... do I still need the firmware upgrade for KC868-A16v3 ??
When will the latest KCS v3 firmware support wiegand please?
Maybe the KCS v3 firmware to support wiegand is only required for non-ESPHome applications?
Thanks,
Paul
