11-25-2025, 12:29 PM
hello. help me figure out the MQTT settings on the KC868 a16 board. the task is to configure the board outputs on a third-party mqtt broker(wqtt.ru ) to work with the voice assistant (Alice)
Mqtt a16
11-25-2025, 11:28 PM
just download KCS v2 firmware by usb-c cable, then set enable mqtt protocol, set the mqtt broker's ip , port, user name, password.
here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
11-26-2025, 05:38 AM
hello. I've already done that. but the web interface shows that there is no confirmation to the mqtt broker
11-26-2025, 05:44 AM
take a photo of your mqtt setting.
11-26-2025, 04:40 PM
(This post was last modified: 11-26-2025, 04:46 PM by davidov.aleksandr1985@gmail.)
Поправьте меня если я где то ошибся.
correct me if I made a mistake somewhere. Поправьте меня если я где то ошибся.
11-26-2025, 11:12 PM
in KCS webpage, you should add "mqtt://" before your mqtt broken domain name.
11-27-2025, 04:17 AM
connected. thank you)))
12-03-2025, 05:24 PM
hello. One more question. when changing the state of the output relay manually (via a switch), should the states of all relays be sent to topik, or just one?
12-03-2025, 11:44 PM
all relay will feedback.
| 1 Guest(s) |
