(01-06-2026, 01:53 PM)admin Wrote: i see. esphome have updated. zmpt101b plugin we need to update again. we will update it, when finished, i will tell you,  you just re compile code, not need to change yaml file.
thanks. much appreciated.
zmpt101b plugin have updated. user "sensitivity" to calibration voltage. my test is "sensitivity: 538", you can try , maybe you need change it. Here is my yaml file, it will print 3 voltage values on the SSD1306 OLED. I have connect L1,L2,L3 together and N1,N2,N3 terminal together. Now you can re compile your code.
    type: arduino
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-zmpt101b
    refresh: 1min
  encryption:
    key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "AC:%.1fV", id(voltage_1).state);
      it.printf(0, 20, id(roboto), "AC:%.1fV", id(voltage_2).state);
      it.printf(0, 40, id(roboto), "AC:%.1fV", id(voltage_3).state);
  - platform: zmpt101b
    name: "m16--AI zmpt 34"
    adc_pin: 34
    sensitivity: 538
    unit_of_measurement: V
    accuracy_decimals: 1
    state_class: "measurement"
    name: "m16--AI zmpt 36"
    adc_pin: 36
    sensitivity: 538
    name: "m16--AI zmpt 39"
    adc_pin: 39
    sensitivity: 538
  - platform: sht3xd
    temperature:
      name: "sht Temperature"
    humidity:
      name: "sht Humidity"
    address: 0x44
    update_interval: 5s
  - platform: adc
    pin: 35
    update_interval: never
    attenuation: 11db
  # - platform: adc
  #   name: "m16--AI-1"
  #   pin: 36
  #   id: adc36
  #   update_interval: 60s
  #   attenuation: 11db
  # - platform: adc
  #   pin: 34
  #   name: "m16--AI-2"
  #   id: adc34
  #   attenuation: 11db
  # - platform: adc
  #   pin: 39
  #   name: "m16--AI-3"
  #   id: adc39
  #   attenuation: 11db
  - platform: cd74hc4067
    sensor: adc35
    sensor: adc35
    sensor: adc35
    sensor: adc35
    number: 4
    sensor: adc35
    number: 5
    sensor: adc35
    number: 6
    sensor: adc35
    number: 7
    sensor: adc35
    number: 8
    sensor: adc35
    number: 9
    sensor: adc35
    number: 10
    sensor: adc35
    number: 11
    sensor: adc35
    number: 12
    sensor: adc35
    number: 13
    sensor: adc35
    number: 14
    sensor: adc35
    number: 15
    sensor: adc35
  - platform: ct_clamp
    sensor: ai1
    name: "Measured Current-1"
    update_interval: 5s
    filters:
      - calibrate_linear:
          # Measured value of 0 maps to 0A
          - 0.0034 -> 0
          # Known load: 4.0A
          # Value shown in logs: 0.1333A
          - 0.31749 -> 8.95608
  - platform: template
    lambda: return id(Measured_Current_1).state * id(voltage_1).state;
    device_class: power
    unit_of_measurement: 'W'
  - platform: total_daily_energy
    name: "Total Daily Energy1"
    power_id: power1
    filters:
        - multiply: 0.001
    unit_of_measurement: kWh
    accuracy_decimals: 3
    icon: mdi:clock-alert
    device_class: energy
    sensor: ai2
    name: "Measured Current-2"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai3
    name: "Measured Current-3"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai4
    name: "Measured Current-4"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai5
    name: "Measured Current-5"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai6
    name: "Measured Current-6"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai7
    name: "Measured Current-7"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai8
    name: "Measured Current-8"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai9
    name: "Measured Current-9"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai10
    name: "Measured Current-10"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai11
    name: "Measured Current-11"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai12
    name: "Measured Current-12"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai13
    name: "Measured Current-13"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai14
    name: "Measured Current-14"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai15
    name: "Measured Current-15"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai16
    name: "Measured Current-16"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
time:
  - platform: sntp
Managed to make some progress.
I've lost my current output. it shows Not Available.
My file is now similar to yours.
you can also use your yaml file. what problem now? no "current"? take a photo of your issue.
(01-10-2026, 12:43 AM)admin Wrote: you can also use your yaml file. what problem now? no "current"? take a photo of your issue.
my currents which worked just before the latest esphome changes is now not being recognized.
the bug fixed. plugin updated plugin and yaml. you can use this yaml file directly.
The zmpt sensor has been disassembled into two parts: one is the original ADC sensor, and the other is the zmpt sensor.
The configuration parameters for zmpt plugin can be found here:
support set parameters : sensitivity/frequency/update_interval
    type: arduino
  - source:
      type: git
      ref: v2.1.0
  encryption:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
display:
    address: 0x3C
    lambda: |-
  - platform: adc
    pin: 34
    attenuation: 12db
  - platform: adc
    pin: 36
    attenuation: 12db
  - platform: adc
    pin: 39
    attenuation: 12db
    sensor: adc34
    sensitivity: 538
    sensor: adc36
    sensitivity: 538
    sensor: adc39
    sensitivity: 538
  - platform: sht3xd
    temperature:
    humidity:
    address: 0x44
    update_interval: 5s
  - platform: adc
    pin: 35
    attenuation: 12db
  # - platform: adc
  #   name: "m16--AI-1"
  #   pin: 36
  #   id: adc36
  #   attenuation: 11db
  # - platform: adc
  #   pin: 34
  #   name: "m16--AI-2"
  #   id: adc34
  #   attenuation: 11db
  # - platform: adc
  #   pin: 39
  #   name: "m16--AI-3"
  #   id: adc39
  #   attenuation: 11db
    sensor: adc35
    sensor: adc35
    sensor: adc35
    sensor: adc35
    number: 4
    sensor: adc35
    number: 5
    sensor: adc35
    number: 6
    sensor: adc35
    number: 7
    sensor: adc35
    number: 8
    sensor: adc35
    number: 9
    sensor: adc35
    number: 10
    sensor: adc35
    number: 11
    sensor: adc35
    number: 12
    sensor: adc35
    number: 13
    sensor: adc35
    number: 14
    sensor: adc35
    number: 15
    sensor: adc35
    sensor: ai1
    update_interval: 5s
    filters:
      - calibrate_linear:
          - 0.0034 -> 0
          # Known load: 4.0A
    device_class: power
    power_id: power1
    filters:
        - multiply: 0.001
    sensor: ai2
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai3
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai4
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai5
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai6
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai7
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai8
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai9
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai10
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai11
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai12
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai13
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai14
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai15
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai16
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
time:
  - platform: sntp
yaml file download:
.txt   M16v2_HA.txt (Size: 9.37 KB / Downloads: 339)
I'm updating you on the situation with my m16v2:
- The LAN connection still isn't working. I'm only using the board via Wi-Fi. What a shame...
- The CT reading accuracy is "dirty." Even with the clamp disconnected, it can detect up to 0.3A.
- I modified the yaml file by inserting 16 entities to calculate power in W and 16 channels for energy calculation in kWh.
I then added a "filter" to prevent current readings below 0.3A from being calculated, as they would be false.
It's a shame because the board can't actually detect power below 50-60W with sufficient accuracy.
if you really can't work with M16v2. we can send you a N20 energy meter board, it's new version.
No, the card won't work below 50-60W. It gets dirty readings with disconnected sensors, even at 0.30A.
Can you send me an M20 card to replace the M16v2?
send me your order number, we will send you a new N20, the old M16v2 board you not need send back to us.
