KCS debounce option for KC868-A16 v1.6
I have a KC868-A16 running KCS v2.2.20,
integrated with Home Assistant via MQTT.
Input 16 reads an auxiliary contact of a latching relay (Finder 20.22)
to get the real ON/OFF state of a light. While the contact is closed
(input ON), I occasionally get a false OFF lasting 1-2 seconds, then
the input goes back to ON by itself. These glitches are published
immediately via MQTT.
I saw in this thread that you added an input debounce option
("input delay time") to the KCS v3 firmware for the KC868-A16v3:
https://www.kincony.com/forum/showthread.php?tid=9119
My questions:
1. Is there (or will there be) a KCS firmware with the same debounce
  option for the KC868-A16 with ESP32 (not v3)?
2. What is the maximum debounce time that can be set? In my case
  I would need about 2-3 seconds.
3. Is the debounce setting global or can it be set per input?
4. If I upgrade from KCS v2 to v3, do the MQTT topics and the JSON
  payload format (e.g. {"input16":{"value":true}}) stay the same?
Thank you!
KCS v2 use for ESP32, KCS v3 use for ESP32S3, they are different hardware.
now KCS v2 stop update. if you want use "debounce" option, you can config by ESPHome.
Isn't it possible to have custom firmware for the v2 version with the debounce option? I have 5 KC868-A16 v2.
Thanks for the support.
sorry, KCS v2 is no longer being updated; all current updates and maintenance are based on KCS v3.
