11-20-2026, 05:29 PM
I am trying to understand how does the N60 asrrive with the energy reading for each channel. I have calibrated current and power readings but did not do anything with energy coefficient and its left at 1.
Does energy coefficient also have to be calibrated or is the value calculated from from voltage current and power factor.
I am seeing very large difference between actual energy reading between tow channesl that monitor total consumed power being measured on the incoming lines vs total power used for individual channels and do not understand why. The only reason that comes to mind mould be the need for calibrating the kWH coefficient.
Please see that attached pic which is from Homeassistant Energy dashboard. Ch1 L1 Main left and CH1 L2 Main right are the main power feeds coming in. (top graph) the bottom are the individual breakers with total energy exceeding the top graph measurements. This also results in negative grey bar at on the bottom graph dispalying the difference.
Can you tell me how would I address this.
I am running the latest code on the n60
Thank you in advance.
