01-22-2021, 02:25 PM
Hello! Is it possible to connect COL and Domoticz?
k868 COL and Domoticz
01-23-2021, 01:18 AM
now relay controller support use by Domoticz. COL not support.
01-24-2021, 06:37 AM
will it be possible in future?
01-24-2021, 08:11 AM
maybe, but now not have the plan.
01-27-2021, 01:03 PM
Instead of domoticz can I connect COL with Home Assistant?
01-28-2021, 12:48 AM
yes, no problem. home assistant is also easy to integration.
if you can write code, you can modify our relay controller's python source code for KC868-COL to use. that have share in our github.
Hello! Have some problems with import NODe_RED-COL file to home assistant!IT doesnt undestand some types - type of digital sensor and temperature/ i can fix it by your youtube video but there isnt discription for LEVEL box after temperature sensor. can you explain what I shold type there. or export correct node red file for current Home Assistant! thanx
Ps And maybe you can post here you config.yaml for adding all this sensors?)
01-30-2021, 01:25 AM
before import flows , you need install these nodes for Node-Red:
1. node-red-contrib-ui-led 【LED UI】 2. node-red-contrib-ui-level 【Temperature】 3. node-red-dashboard 【dashboard UI】
01-30-2021, 06:15 AM
Thanx! now its imports well!
so how can I add sensors to lovelace? And if I connect kc868-h8 with COL by rs232 what command I should send by TCP Socket to control relay?
01-30-2021, 08:54 AM
KC868-H8 and KC868-COL both connect with Node-Red by different IP is ok. not need to use RS232 cable.
