Hey!
Im new and just discovered the Kincony relays and its probably the best solution for my problem
My goal is basically: I want to be able to get an event in home assistant when I press the RF remote or a toggle switch to open the garage/gate door, so I can create an automation primarily to turn on the lights at night
I would only use the Kincony relay for the garage door and gate, my lights are already connected to home assistant
eg
toggle switch button was pressed, garage door opens -> turn on lights for 5min
or RF remote button was pressed, garage door opens -> turn on lights for 5min
Im a bit confused on 2 things
It says on the website the outputs are "277VAC 10A, 125VAC 12A", and I see nearly all other relay described as AC output aswell, the garage door and the gate is a 12v relay, can I still connect it?
When I connect a normal toggle light switch on the inputs to open the garage, can I set it up in "hold" and "toggle" mode or how is that managed?
Thank you!
eg
Thank you!
