03-23-2022, 12:36 PM
platform: ESP32
- id: bus_a
sda: 15
scl: 13
- id: bus_b
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
i2c_id: bus_a
address: 0x24
i2c_id: bus_a
address: 0x25
- id: 'pcf8574_hub_out_3' # for output channel 17-24
i2c_id: bus_a
address: 0x21
- id: 'pcf8574_hub_out_4' # for output channel 25-32
i2c_id: bus_a
address: 0x22
i2c_id: bus_b
address: 0x24
i2c_id: bus_b
address: 0x25
- id: 'pcf8574_hub_in_3' # for input channel 17-24
i2c_id: bus_b
address: 0x21
- id: 'pcf8574_hub_in_4' # for input channel 25-32
i2c_id: bus_b
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_3
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_4
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
pcf8574: pcf8574_hub_in_2
number: 4
number: 5
number: 6
number: 7
pcf8574: pcf8574_hub_in_3
number: 4
number: 5
number: 6
number: 7
pcf8574: pcf8574_hub_in_4
number: 4
number: 5
number: 6
number: 7
- platform: adc
pin: 39
update_interval: 10s
attenuation: 11db
- platform: adc
pin: 34
attenuation: 11db
- platform: adc
pin: 36
attenuation: 11db
- platform: adc
pin: 35
attenuation: 11db
platform: ESP32
- id: bus_a
sda: 15
scl: 13
- id: bus_b
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
i2c_id: bus_a
address: 0x24
i2c_id: bus_a
address: 0x25
i2c_id: bus_a
address: 0x21
i2c_id: bus_a
address: 0x22
i2c_id: bus_b
address: 0x24
i2c_id: bus_b
address: 0x25
i2c_id: bus_b
address: 0x21
i2c_id: bus_b
address: 0x22
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 4
number: 5
number: 6
number: 7
number: 4
number: 5
number: 6
number: 7
number: 4
number: 5
number: 6
number: 7
number: 4
number: 5
number: 6
number: 7
- platform: adc
pin: 39
attenuation: 11db
- platform: adc
pin: 34
attenuation: 11db
- platform: adc
pin: 36
attenuation: 11db
- platform: adc
pin: 35
attenuation: 11db
