KC868-AP
#21
do you want input click one time, light ON, click one time, light OFF?
(05-07-2023, 04:33 AM)admin Wrote: do you want input click one time, light ON, click one time, light OFF?
Yes, and I would like to dimer with the button too
I would like to connect a Nextion HMI to a KC868 AIO All in One Controller.
Please advise on best pins to use.
(05-07-2023, 09:04 AM)OloffSmyth Wrote: I would like to connect a Nextion HMI to a KC868 AIO All in One Controller.
if you not use 4G module, you can use 4G socket's RXD,TXD pin for Nextion display.
this is config file for digital input1 with button control KC868-AP output1:
click for ON/OFF LED, hold on for change brightness.
.txt   AP_esphome_eth - INPUT-OUTPUT.txt (Size: 7.16 KB / Downloads: 602)
    type: arduino
  encryption:
    key: "hx8eSqbwjWs9/2bK0qK55QfTIOpI4gCfzLOeaOXZMaU="
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 16
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8    maybe 0x22  /  0x3A
    address: 0x22
    address: 0x21
      pcf8574: pcf8574_hub_in_1
    on_click:
      then:
        - if:
            condition:
              light.is_off: light_1
            then:
              light.turn_on:
                brightness: 1.0
            else:
              light.turn_off: light_1
    on_press:
      then:
      - if:
          condition:
          then:
          - delay: 0.5s
          - while:
              condition:
                binary_sensor.is_on: light_1_touch
              then:
                - light.dim_relative:
                    relative_brightness: 5%
                    transition_length: 0.1s
                - delay: 0.1s
          else:
          - delay: 0.5s
          - while:
              condition:
                and:
                  - binary_sensor.is_on: light_1_touch
                  - light.is_on: light_1
              then:
                    relative_brightness: -5%
                - delay: 0.1s
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_2
      number: 4
      number: 5
      number: 6
      number: 7
      number: 34
      number: 35
pca9685:
    frequency: 500
output:
  - platform: pca9685
    pca9685_id: 'pca9685_hub'
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
  - platform: monochromatic
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
    pin: 13
    inverted: false
    pin: 2
    inverted: false
(05-08-2023, 12:49 AM)admin Wrote: this is config file for digital input1 with button control KC868-AP output1:
    type: arduino
  encryption:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  sda: 4
  scl: 16
    address: 0x22
    address: 0x21
    on_click:
      then:
        - if:
            condition:
            then:
              light.turn_on:
                brightness: 1.0
            else:
    on_press:
      then:
      - if:
          condition:
          then:
          - delay: 0.5s
          - while:
              condition:
              then:
                - delay: 0.1s
          else:
          - delay: 0.5s
          - while:
              condition:
                and:
              then:
                - delay: 0.1s
      number: 4
      number: 5
      number: 6
      number: 7
      number: 4
      number: 5
      number: 6
      number: 7
      number: 34
      number: 35
pca9685:
    frequency: 500
output:
  - platform: pca9685
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
    pin: 13
    inverted: false
    pin: 2
    inverted: false
Maybe you can make it save the lighting settings when I turn off the light, because now it lights up at 100% even though it was at 50%?
- if:
            condition:
            then:
              light.turn_on:
                brightness: 1.0
you can change the brightness "1.0" with a low percent value. such as 50% or 30% ....
because "1.0" = 100%
and it is possible to do all this with a button to save the value, for example, which was set last time?
i have not tested it. you can check whether esphome support save variable value. if esphome support, will be no problem do that.
this works the value changes but it can be done with the computer and i want to do it with the button so that it keeps the value that was set with the button.
“SHORT CLICK” button : if your lamp is ON (1%–99%), then will be turn OFF. If your lamp is OFF (0%) , then will be turn ON (set to last time brightness have saved on memory).    I need to act like this
