KC868-A16S ESP32 16 Channel Relay Board Released
We have designed KC868-A16S (ESP32 16 channel relay board) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 16CH relay (MAX AC250V 10A) output + 16CH digital input + 4CH analog input, support RS485 + Ethernet + WiFi + Bluetooth + 4G SIM7600 or 2G SIM800L GSM module + DS3231 RTC module + manual control button panel.
[Image: KC868-A16S-1_01.jpg]
[Image: KC868-A16S-1_02.jpg]
[Image: KC868-A16S-1_03.jpg]
[Image: KC868-A16S-1_04.jpg]
hi admin can we have more tutorial on kc868-a16s thank you
A16S mainly use by ESPHome for home assistant. what software or function you want to use by A16S?
hello admin i have problems with the following code can you help me thanks in advance.
when I send the command the relays do not change state
#include "Arduino.h"
#include "PCF8574.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
// Set i2c address
PCF8574 pcf8574_1(0x24,4,5);
PCF8574 pcf8574_2(0x25,4,5);
// Set these to your desired credentials.
const char *ssid = "kinconny";
const char *password = "01234567";
WiFiServer server(80);
Serial.println();
Serial.println("Configuring access point...");
// You can remove the password parameter if you want the AP to be open.
WiFi.softAP(ssid, password);
IPAddress myIP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(myIP);
server.begin();
Serial.println("Server started");
// Set pinMode to OUTPUT
pcf8574_1.pinMode(P0, OUTPUT);
pcf8574_1.pinMode(P1, OUTPUT);
pcf8574_1.pinMode(P2, OUTPUT);
pcf8574_1.pinMode(P3, OUTPUT);
pcf8574_1.pinMode(P4, OUTPUT);
pcf8574_1.pinMode(P5, OUTPUT);
pcf8574_1.pinMode(P6, OUTPUT);
pcf8574_1.pinMode(P7, OUTPUT);
pcf8574_2.pinMode(P0, OUTPUT);
pcf8574_2.pinMode(P1, OUTPUT);
pcf8574_2.pinMode(P2, OUTPUT);
pcf8574_2.pinMode(P3, OUTPUT);
pcf8574_2.pinMode(P4, OUTPUT);
pcf8574_2.pinMode(P5, OUTPUT);
pcf8574_2.pinMode(P6, OUTPUT);
pcf8574_2.pinMode(P7, OUTPUT);
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("New Client."); // print a message out the serial port
while (client.connected()) { // loop while the client's connected
Serial.write©; // print it out the serial monitor
client.println();
// the content of the HTTP response follows the header:
client.print("Click <a href=\"/H\">here</a> to turn ON the LED.<br>");
client.print("Click <a href=\"/L\">here</a> to turn OFF the LED.<br>");
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
break;
} else { // if you got a newline, then clear currentLine:
currentLine = "";
// Check to see if the client request was "GET /H" or "GET /L":
if (currentLine.endsWith("GET /H")) {
pcf8574_1.digitalWrite(0, LOW);
pcf8574_1.digitalWrite(1, LOW);
pcf8574_1.digitalWrite(2, LOW);
pcf8574_1.digitalWrite(3, LOW);
pcf8574_1.digitalWrite(4, LOW);
pcf8574_1.digitalWrite(5, LOW);
pcf8574_1.digitalWrite(6, LOW);
pcf8574_1.digitalWrite(7, LOW);
pcf8574_2.digitalWrite(0,LOW);
pcf8574_2.digitalWrite(1,LOW);
pcf8574_2.digitalWrite(2,LOW);
pcf8574_2.digitalWrite(3,LOW);
pcf8574_2.digitalWrite(4,LOW);
pcf8574_2.digitalWrite(5,LOW);
pcf8574_2.digitalWrite(6,LOW);
pcf8574_2.digitalWrite(7,LOW);
delay(1000);
if (currentLine.endsWith("GET /L")) {
pcf8574_1.digitalWrite(0, HIGH);
pcf8574_1.digitalWrite(1, HIGH);
pcf8574_1.digitalWrite(2, HIGH);
pcf8574_1.digitalWrite(3, HIGH);
pcf8574_1.digitalWrite(4, HIGH);
pcf8574_1.digitalWrite(5, HIGH);
pcf8574_1.digitalWrite(6, HIGH);
pcf8574_1.digitalWrite(7, HIGH);
pcf8574_2.digitalWrite(0,HIGH);
pcf8574_2.digitalWrite(1,HIGH);
pcf8574_2.digitalWrite(2,HIGH);
pcf8574_2.digitalWrite(3,HIGH);
pcf8574_2.digitalWrite(4,HIGH);
pcf8574_2.digitalWrite(5,HIGH);
pcf8574_2.digitalWrite(6,HIGH);
pcf8574_2.digitalWrite(7,HIGH);
delay(1000);
// close the connection:
client.stop();
Serial.println("Client Disconnected.");
which model board you are using?
kc868 a16s
here is demo source code, how to control OUTPUT by KC868-A16S:
https://www.kincony.com/forum/showthread.php?tid=2793
Ok admin, yes I used this piece of code in my code but I'm having trouble getting it to work.
is there? a similar pc-kc868-h32b application for the a16s?
do you means PC software for A16S? use in local network? we have a PC software for A16S. but use in local network.
(06-06-2023, 12:04 AM)admin Wrote: do you means PC software for A16S? use in local network? we have a PC software for A16S. but use in local network.
 hello ,
what is the pc software that use in local network ?
please  link the pc software
