error instal A128
Hi every one
when i try to instal A123, i get error
ERROR Serial port closed!
see attach
need details? do you use raspberry pi for home assistant?
no i used Generic x86-64
check your server port, such as whether have installed USB-serial driver, we use CH340 chip for USB-serial convert.
you know how to check server port on servers
check USB port whether is "enabled", in home assistant hardware resource webpage can see it.
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/001
DEVNUM: '001'
DEVPATH: /devices/pci0000:00/0000:00:14.0/usb1
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-pci-0000_00_14_0
ID_MODEL: xHCI_Host_Controller
ID_MODEL_ENC: xHCI\x20Host\x20Controller
ID_MODEL_ID: '0002'
ID_PATH: pci-0000:00:14.0
ID_PATH_TAG: pci-0000_00_14_0
ID_REVISION: '0601'
ID_SERIAL: Linux_6.1.45_xhci-hcd_xHCI_Host_Controller_0000:00:14.0
ID_SERIAL_SHORT: '0000:00:14.0'
ID_USB_INTERFACES: ':090000:'
ID_USB_MODEL: xHCI_Host_Controller
ID_USB_MODEL_ENC: xHCI\x20Host\x20Controller
ID_USB_MODEL_ID: '0002'
ID_USB_REVISION: '0601'
ID_USB_SERIAL: Linux_6.1.45_xhci-hcd_xHCI_Host_Controller_0000:00:14.0
ID_USB_SERIAL_SHORT: '0000:00:14.0'
ID_USB_VENDOR: Linux_6.1.45_xhci-hcd
ID_USB_VENDOR_ENC: Linux\x206.1.45\x20xhci-hcd
ID_USB_VENDOR_ID: 1d6b
ID_VENDOR: Linux_6.1.45_xhci-hcd
ID_VENDOR_ENC: Linux\x206.1.45\x20xhci-hcd
ID_VENDOR_ID: 1d6b
MAJOR: '189'
MINOR: '0'
PRODUCT: 1d6b/2/601
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 9/0/1
USEC_INITIALIZED: '1869716'
when you connect USB cable to esp32 board, there should be one usb-serial device.
make sure your usb cable have connect to home assistant server's USB port.
i used mini pc as Generic x86-64
A128 usb cable connect to your miniPC's USB port. then check in your home assistant hardware resource.
