KC868-A8S - Trying to connect with GSM
Hi!  Big Grin
I have recently purchased a KC868-A8S.
My goal is to get a GSM web server, from which I can activate the relays.
I have managed to create a web server by creating my own AP, taking a tutorial from the forum as an example.
But this, although it is something similar, does not serve my purpose.
I have worked before with ESP32 and GSM (I used to work with TinyGSM), and when I wanted to connect it was necessary to define the MODEM_TX and MODEM_RX pins in code.
In this case I cannot find anywhere, neither in the documentation nor in the forum, how to connect the ESP to the GSM network, nor to which pins the modem corresponds.
I have a SIM800L module.
Is there an example of code (.ino) in which the configuration and connection of the GSM can be seen logically?
Any help is appreciated.
Thank you very much in advance and sorry for my level of English.
hello, here have many GSM module demo source code for A8S: https://www.kincony.com/forum/forumdisplay.php?fid=24
it's enough for you to use.
