KC868-H16B
Does not work in WI-FI server mode
from my smartphone I can't see the controller in the window of available WI-FI networks
I pressed the WI-FI server button. the green LED flashes, but there is no result
What's the matter?
connection modes are also poorly switched, both on WI-FI and wired connection (Client,server, UDP)
In the client function when connected via cable, it is also not controlled
please say your problem details. which product model you are using? what do you want to do?
