Lesson22 - add RGBW LED strip to home assistant by ESPHome
#11
yes, all power suplly's "GROUND" should connected together.
I connected the 24V(-) power supply of AIO with 5V(-) power supply of led strip and all works fine now.
ok
Can you advise why i get this errors ?
i think your config yaml is wrong, chosed wrong chip type. it's not AVR.
(06-27-2023, 05:15 AM)admin Wrote: i think your config yaml is wrong, chosed wrong chip type. it's not AVR.
I resolved the issue by reinstalling home assistant and added and ssd extention via USB to compute module and i moved all the data to ssd.
Now all working smooth.
ok, good.
