KC868-UAIR ESPHOME Config for IR and RF
#28
(05-20-2022, 11:53 AM)admin Wrote: esphome:
    type: arduino
wifi:
  ssid: kincony
  password: xxxx
captive_portal:
remote_receiver:
  - id: RF_Receiver
    pin: 13
    dump:
      - rc_switch
    tolerance: 50%
    filter: 250us
    idle: 4ms
  - id: IR_Receiver
    number: 19
    inverted: True
    dump: all
dallas:
  - pin: GPIO27
    update_interval: 15s
  - platform: dallas
    address: 0xad0000000b19c128
    name: "internal Temperature"
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812
    pin: GPIO32
    num_leds: 4
    method: ESP32_RMT_1
    effects:
      - addressable_rainbow:        ##defined 7 effects styles
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
    type: RGB
    variant: WS2812
    pin: GPIO33
    num_leds: 1
    method: ESP32_RMT_2
    effects:
      - addressable_scan:
Thanks for sending that through.  I put that config in and after ESPHome loaded the new config one of the bottom LEDs came on white all the time and the vertical LED is also on all the time and is red.  The KC868-UAIR does this after being powered off and on again. Home Assistant cannot run these lights off.
I took the light config out and but the device will not upload the new firmware any more.  I've uploaded the config for that and the error log for you to see.  It gets a few percentage points into the upload and then aborts.  I've powered off and on again, simplified the config to the minimum possible and it does the same each time.
So the extra changes you put in have taken me back a step as I can no longer upload firmware the the KC868-UAIR and the lights don't work.
What would you like me to do now?
.txt   failure.config.txt (Size: 1.32 KB / Downloads: 193)
.txt   failure logs_kc868-uair_upload.txt (Size: 1.16 KB / Downloads: 168)
RE: KC868-UAIR ESPHOME Config for IR and RF - by dmshimself - 05-20-2022, 09:57 PM
