KC868 H32B in home assistant
hello engineer could you please help my in home assistant
when i add KC868 H32B to home assistant .needed to make one switch control all On and Off like attached photos.
here is document: https://www.kincony.com/kc868-h32b-integ...-mqtt.html
here is video tour: https://www.youtube.com/watch?v=Yrat7hVzXRw
Hello engineer
When I make 2 lights from helper . How can we collect in one switch.  All On and Off . like above photos .
click "show visual editor", then you will see a option, just "enable" it , you will see the new button for "ALL ON/OFF".
(05-19-2022, 06:43 AM)admin Wrote: click "show visual editor", then you will see a option, just "enable" it , you will see the new button for "ALL ON/OFF".
thanks so much. its okay same you said Wink Wink
