kincony_kc-H868B_relay32B HomeAssistant Mqtt Not Working After 2022.12.0 Update
I updated HOME ASSISTANT to the latest version and now I get an error message.
The controller is an H32B model, And the connection is via MQTT.
I can't connect to the controller and nothing is responding, through the HOMEASSISTANT interface.
Before the update I could activate all the relays and see the state of the inputs.
The controller itself works and I can enter the settings through the WEB interface.
This is the message I see in the HOME ASSISTANT interface:
https://im.ge/i/Screenshot-2[img]Manually configured MQTT switch(s) found under platform key switch.[/img]022-09-08-15552800002.OkBDd9
[Image: 72a659600ea6bc80f7ff00799a07540993a558fc.png]
I am attaching a picture of the settings:
[Image: 70496a3eda87726c9a2f3732b93f4167e3db657b.png]
I tried to change the settings to the new format as shown in the instructions and that doesn't work either.
[Image: 159df7bd75704d204ff13ac4286a5dfe7b75fbc3.png]
I assume the problem stems from incorrect settings in the CONFIGURATION.YAML file.
The format should probably be changed.
I would love to get help please.
Thanks in advance,
Shemi Cohen
new home assistant have updated MQTT config. see this link: https://www.kincony.com/forum/showthread.php?tid=1998
