KC868-A64 DS18B20
(09-19-2022, 03:18 PM)- flatulentflamingo Wrote:
(09-15-2022, 01:30 PM)admin Wrote: KC868-A64 support analog sensor (dc 0-5v) , i2c sensor directly. if you want to use 1-wire sensor, you can connect to one of serial port's pin on the PCB. just need add a  pull-up resistance.
Your kc868-a series product series look very interesting. The kc868-ai in particular looks like a great fit for home automation.
I have star topology cat5e wiring. I would love a product that would let me connect multiple 1-wire sensors (ds18b20, ...) cleanly. Without soldering pull-up resistors. Just like you enabled for binary sensor input.
Is that something on your road map?
Thank you. I understand that. I have implemented ds18b20 like that before. It looks bad. It is more difficult to maintain than it should be. The most likely to go wrong would be a 1-wire bus unhappy with the sensor network topology. I want a clean, maintainable, wired solution.
My dream board for temperature sensing I would call KC868-AT:
- ESP32 board
- all free gpio's exposed
- per gpio: 4.7k Ohm pullup resistor between vcc and data preinstalled on board
- per gpio: screw terminals for vcc, data and gnd on a removable screw terminal block
- ethernet (like KC868-AI, KC-868-A16, ...)
- (optional) a set of ds18b20 sensors and wago style clamps to connect them
- ready-to-go esphome config
This should be relatively easy to build with 8 temperature sensor slots. No need even for any gpio extenders.
Will you please build this? I will buy a few. More people would buy this!
KC868-A64 DS18B20 - by janosch1337 - 09-15-2022, 01:18 PM
RE: KC868-A64 DS18B20 - by admin - 09-15-2022, 01:30 PM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 09-19-2022, 03:18 PM
RE: KC868-A64 DS18B20 - by maro1977pl - 12-15-2022, 05:40 PM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 01-06-2023, 03:49 PM
RE: KC868-A64 DS18B20 - by admin - 09-19-2022, 09:50 PM
RE: KC868-A64 DS18B20 - by admin - 12-15-2022, 10:51 PM
RE: KC868-A64 DS18B20 - by admin - 01-07-2023, 01:38 AM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 01-07-2023, 07:21 AM
RE: KC868-A64 DS18B20 - by admin - 01-07-2023, 01:57 PM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 01-07-2023, 02:30 PM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 01-07-2023, 08:41 PM
RE: KC868-A64 DS18B20 - by admin - 01-08-2023, 02:04 AM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 01-28-2023, 01:53 AM
RE: KC868-A64 DS18B20 - by admin - 01-28-2023, 02:27 AM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 01-28-2023, 11:14 AM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 02-17-2023, 07:56 AM
RE: KC868-A64 DS18B20 - by admin - 01-28-2023, 01:56 PM
RE: KC868-A64 DS18B20 - by admin - 02-17-2023, 09:49 AM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 03-13-2023, 01:50 PM
RE: KC868-A64 DS18B20 - by admin - 03-13-2023, 10:41 PM
RE: KC868-A64 DS18B20 - by admin - 03-14-2023, 10:47 AM
RE: KC868-A64 DS18B20 - by flatulentflamingo - 03-14-2023, 12:52 PM
RE: KC868-A64 DS18B20 - by admin - 03-14-2023, 01:00 PM
RE: KC868-A64 DS18B20 - by admin - 03-20-2023, 02:10 AM
