KC868-D16 dimmer controller with LED driver
#13
“HOLD ON” button : the output1 brightness will increase brightness until to 99% –> 0% –>99% –>0% –>99% always loop.
“SHORT CLICK” button : if your lamp is ON (1%–99%), then will be turn OFF. If your lamp is OFF (0%) , then will be turn ON (set to last time brightness have saved on memory).
here is details: https://www.kincony.com/how-to-use-kc868...oller.html
We strongly recommend that the manual switch be controlled by the hardware itself, not by the home assistant. This is the most reliable way. If the home assistant fails or your Raspberry Pi fails, the lights in the room will not be manually controlled, which is very troublesome.
RE: KC868-D16 dimmer controller with LED driver - by admin - 12-22-2022, 01:13 AM
