wifi port as AP in home Assistant
Hello friends,
Is there are possibility to use LAN port for connection to the local network, and wifi to be used like AP for connecting other smart devices? Everything of that configurated within esphome. Currently I use KC868-A8S with Home assistant, and it is connected with a wifi. Also I can't change the configuration to be connected with ethernet port.
Thanks a lot
sorry, you can chose only one way for ethernet or wifi.
