KC868-A2 configure yaml for ESPhome
KC868-A2 configure yaml for ESPhome by Ethernet or WiFi.
.txt   ESPHome_KC868-A2-ethernet.txt (Size: 732 bytes / Downloads: 381)
.txt   ESPHome_KC868-A2-wifi.txt (Size: 875 bytes / Downloads: 288)
Hi
Great product.... but how do we use a SIM7600 (4g modem) with ESPHome to send SMS text messages to / from the device?
Thank you!
ESPHome only support 2g modem SIM800L to send SMS. maybe i will feedback to ESPHome support 4G module.
Yes - please do ask ESPHome to support SIM7600! Your videos show SIM7600 being plugged in, and you talk about ESPHome - but this combination cannot be used.
Many countries are closing down 2g network. More will follow..... so SIM7600 support for the KC868-A2 is very important.
I think the commands are very similar - so probably only very small changes required to the ESPHome SIM800 code? Maybe someone at your company has the skills to suggest the required changes and make a pull request? https://github.com/esphome/esphome/tree/...ts/sim800l
Australia
Telstra – Closed in December 2016
Optus – Closed in August 2017
Vodafone – Closed in June 2018
Bahrain
Batelco – Closed in November 2021
Belgium
Orange – Closing before December 2030
Brunei
DST – Closed in June 2021
Imagine - Closed in June 2021
Progresif - Closed in June 2021
Canada
Telus – Closed in May 2017
Rogers – Closed in December 2021
Bell – Closed in April 2019
China
China Telecom – Closed in June 2020
China Unicom – Closed in December 2021
Colombia
Claro – Closing before December 2022
France
Orange – Closing before December 2025
Germany
Vodafone – Closing before December 2025
Hong Kong
Three – Closed in September 2021
China Mobile – Closed in December 2021
HKT – Closed in September 2021
SmarTone – Closed in December 2021
Israel
Partner Communications – Closing before December 2025
Cellcom – Closing before December 2025
Italy
Telecom Italia – Closing before December 2029
Japan
Softbank – Closed in March 2010
NTT Docomo – Closed in March 2012
KDDI – Closed in 2020
Luxembourg
Mexico
AT&T – Closed in March 2019
Movistar – Closed in January 2021
Netherlands
T-Mobile – Closing before June 2023
New Zealand
2degrees – Closed in March 2018
Spark – Closed in July 2012
Norway
Telenor – Closing before December 2025
Telia – Closing before December 2025
Pakistan
Poland
Romania
Singapore
MobileOne – Closed in April 2018
Singtel - Closed in April 2018
Starhub - Closed in April 2018
Spain
Slovakia
South Africa
Telkom – Closed in 2020
South Korea
KT – Closed in March 2012
LG Uplus – Closed in June 2021
SK Telcom – Closed in July 2020
Switzerland
Swisscom – Closed in December 2020
Sunrise – Closing before December 2022
Taiwan
Chunghwa Telecom – Closed in June 2017
FarEasTone – Closed in June 2017
Taiwan Mobile – Closed in June 2017
United Arab Emirates
Du – Closing in December 2022
Etisalat – Closing in December 2022
United Kingdom
EE – Closing before December 2033
Vodafone – Closing before December 2033
O2 – Closing before December 2033
Three – Have never run a 2G network
United States
AT&T – Closed in January 2017
T-Mobile – Closing before December 2022
Verizon – Closed in December 2020
At least initially, maybe sim7600 support could be added as an external component to esphome?
https://esphome.io/components/external_components.html
we will contact with esphome about the 4G needs.
Good day, I have one of these units set up with esphome. I'm using the recommended yaml for ethernet connection.
My intention was to use the board to restart my router when the internet fails. So the board powers the router and at the same time is connected to the router via the ethernet port.
The problem I have is that when I power cycle the board or associated relay powering the router, the esp32 chip does not reconnect to the network.
I can see the board connected to the network with it's associated IP address, but the esp32 does not seem to connect and therefore the board is inaccessible. I cant see it in homeassitant or on the assigned ip address webui.
If I just use it to power something else and it doesn't loose Ethernet connection, then it works fine.
However, as I explained the use case was as an internet 'watchdog'.
Is there an additional setting I must add to the esphome yaml?
See below my esphome yaml for reference
substitutions:
  friendly_name: networksocket
    type: arduino
web_server:
  port: 80
  encryption:
    key: "key"
  services:
  - service: power_cycle_relay1
    then:
    - switch.turn_off: relay1
    - delay: 30s
    - switch.turn_on: relay1
  - service: power_cycle_relay2
    then:
    - switch.turn_off: relay2
    - delay: 30s
    - switch.turn_on: relay2
  - service: power_cycle_esp
    then:
    - delay: 5min
    - button.press: ${friendly_name}_restart
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
- id: bus_a
  sda: GPIO4
  scl: GPIO5
  pin: 15
  inverted: false
  restore_mode: RESTORE_DEFAULT_ON
  pin: 2
  inverted: false
    number: 36
  on_press:
    then:
    - switch.toggle: relay1
    number: 39
  on_press:
    then:
    - switch.toggle: relay2
- platform: uptime
text_sensor:
- platform: version
  name: ${friendly_name} ESPHome Version
- platform: ethernet_info
  ip_address:
    name: ${friendly_name} IP Address
time:
- platform: homeassistant
# https://esphome.io/components/esp32_ble_tracker.html
esp32_ble_tracker:
  scan_parameters:
    active: true
# https://esphome.io/components/bluetooth_proxy.html
bluetooth_proxy:
  active: true
button:
- platform: restart
  entity_category: config
  disabled_by_default: false
  device_class: restart
Thank you
i think you can use esphome to visit one internet URL, if can't visited, then use relay ON/OFF for your router's power supply.
(09-26-2023, 11:57 PM)admin Wrote: i think you can use esphome to visit one internet URL, if can't visited, then use relay ON/OFF for your router's power supply.
Thank you that is not the problem.
The problem is that if the board is initiated before it has a LAN connection (while the router is starting) then the esp32 does not connect, there's no webgui in the assigned IP.
The board is connected to the network, because it's connected via ethernet, so I can see it in my router webpage, but it doesn initiate or start the esp32 in esphome. There's no control.
If I restart the board, while it has a 'live' network connection, then it works fine.
It just doesn't work correctly when it's initiated  without a network connection.
if router not ready, esp32 will always try to connect with ethernet connection.
you can download KCS firmware for a test. just let esp32 board power on, then router power off, wait for a moment, router power on, then check esp32 whether is connected to router by ethernet.
