self-reset momentary wall switch panel for rectangular wall box type 118
Hi.
I'm looking for a wall switch panel that fits into the boxes currently installed in my walls. I think it's usually called "type 118"; where 118mm is the nominal width of the outer panel case. The wall box is rectangular of width ~100mm and height ~65mm (the distance between the screws is 85mm). A picture of the box is attached below.
Unfortunately, the switches sold in Kincony's store don't fit into such box. The momentary switches they usually sell in my country (that do fit these boxes) are very expensive.
Thanks a lot!
if you have KC868-COL or KC868-COLB, you can work with this old switch panel. not must need momentary. here is video guide link: https://youtu.be/jbuSTVcGdPc
this video is using 118 size , as same as your panel.
(06-22-2021, 01:01 AM)admin Wrote: if you have KC868-COL or KC868-COLB, you can work with this old switch panel. not must need momentary. here is video guide link: https://youtu.be/jbuSTVcGdPc
Thanks. Just to make sure i understand it all correctly: if i set the action to 'toggle' (as the video suggests), I can use both the DI with the classic switch and also a momentary push button (using the switches board) on the same relay. In such constellation both the momentary push button and the classic switch would be able to operate together to change the state of the same relay. Is it correct?
yes, just use 2 ports of DI. such as DI1 connect to your classic switch, make a IFTTT command-A.
DI2 connect to your momentary switch, make a IFTTT command-B.
commmand-A and command-B you can use for turn ON/OFF same relay output or different relay output, it's up to your setting.
