kc868-a6 use 2 sensor inputs for analog input
Is there any way to use the two sensor inputs:
[Image: a6-connections.jpg]
I mean the two IO1 and IO2 pins.
is there any way I can read/connect a 0-10 volt sensor to and read out the voltage/analogvalue?
thanks for any help in advance!
IO1 and IO2 use by digital signal, not for analog input, if you want to use analog input, please use A1,A2,A3,A4 ports.
