Dead Board?
I have a KC868-A8.
I Flashed it fine four days ago using ESP Home on windows 11.  The board is connected to a regulated switched-mode 12v supply.  I had started to program up a script to use as an aquaponics controller.  I had the following connected:
One dry contact on the first input
One TDS sensor on A1  (+4v)
One DS18B20 on S1
All was working well.  I left the board running overnight.
Came back this morning and noticed that it wasn't showing up in Home Assistant or responding to its IP address.
Power was still OK everywhere.
I have attempted to reflash using esphome webtools and using ESP flasher and your own
 tool from here:  ESP Module Flash Download Tools - Smart Home Automation | KinCony
I have rebooted and reinstalled the com port.
I have tried from my mac.
The Serial port is showing up on USB connection on both the mac and PC.
I have tried with a different USB cable.
I have confirmed I am able to flash other esp32 chips from the PC with no problem.
I have tried using the s1 and s1 as boot buttons.
My assumption is that the board is dead unless you have other advice?
config for reference:
I had yet to attach the Ph probe as I was building a voltage divider this morning. Also the Ultrasonic sensor requires some extra files for the build and i had yet to but those in the right place.
# Basic Config
  friendly_name: Greenwall
    type: arduino
  encryption:
    key: !secret greenwall_api_key
ota:
wifi:
  ssid: !secret wifi_ssid
  domain: !secret local_domain
  ap:
    ssid: "Esphome-Web-E12294"
    password: "sJdgDQKbR936"
captive_portal:
web_server:
  port: 80
  auth:
    username: !secret web_server_username
    password: !secret gw_web_server_password
#ethernet:
#  type: LAN8720
#  mdc_pin: GPIO23
#  mdio_pin: GPIO18
#  clk_mode: GPIO17_OUT
#  phy_addr: 0
  - id: 'pcf8574_hub_out_1'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8
    address: 0x22
  sda: 4
  scl: 5
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
    name: "Swirl Filter Pump"
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
# Inputs
# Binary
    name: "Tank Level Low"
      pcf8574: pcf8574_hub_in_1
    name: "Swirl Level Low"
    name: "Bio Level Low"
    name: "Tank Overflow"
      number: 4
      number: 5
      number: 6
      number: 7
# Digital
      number: 32
      number: 33
dallas:
  - pin: 14
  - platform: dallas
    #address: 0x1c0000031edd2a28 #replace with your sensor's ID
    index: 0
    name: "Water Temperature"
  - platform: ultrasonic
    trigger_pin: 13
    echo_pin: 32
    update_interval: 1s
    accuracy_decimals: 2
    filters:
    - lambda: return (1 - x + 0.03);
    - median:
        window_size: 20
        send_every: 10
    unit_of_measurement: "m^3"
# Analog
# pins 34/35
  # https://esphome.io/components/sensor/adc.html
  - platform: adc
    pin: 34
    update_interval: 1s
    unit_of_measurement: pH
    # https://esphome.io/components/sensor/ind...or-filters
    filters:
      - median:
          window_size: 7
          send_every: 4
          send_first_at: 3
      # Measured voltage -> Actual pH (buffer solution)
      - calibrate_linear:
          - 0.59 -> 7.0
          - 0.71 -> 4.0
  - platform: adc
    pin: 35
    update_interval: 1s
    unit_of_measurement: ppm
    filters:
      - lambda: return (x * 1000);
      - median:
          window_size: 7
          send_every: 4
          send_first_at: 3
      # Measured voltage -> Actual TDS (buffer solution)
      #- calibrate_linear:
      #    - 0.59 -> 7.0
      #    - 0.71 -> 4.0
what problem now? can't download firmware? what power supply you have used? dc12v xxA?
the esp32 appears to be 'dead'
it was running fine using esphome. Now it is not responding and I am not able to flash / download any firmware.
The power supply is 150w PC power supply so 12v ~ 10A. I have a bench supply also 12v 6a.
The board shows power but I cannot flash.
The device shows up as a valid COM port but the flashing software is not able to make a connection to initialise the device
can you change another USB-C cable? not use USB hub. or change another USB port of your computer.
(09-22-2023, 08:20 AM)admin Wrote: can you change another USB-C cable? not use USB hub. or change another USB port of your computer.
please read my original message
i have tried:
different USB cables
different ports
different computers
reinstalling the com port
I have verified that the cable and PC works by programming a different esp32 and and esp8266
If it worked and now it doesn't.  Unless you have another suggestion to force reset / enable Flash i have to assume this is broken?
I received the board two days ago and it's been worked on on an antistatic workbench. I think there must be a defect for it to fail so soon?
I can post a video if helpful?
ok, take a video send to whatsapp number: +86-15381188302
