KC868-H32BS roller blinds control
Hi.
Need an advice on wiring and programming 2 roller blinds. Normally, these should have been operated by 3 wires each, just that i have only 5 in total.
My question if it would work to use L as com for all 4 output relays, as follows
L -COM
N1- UP
N2-DOWN
N3-UP
N4-DOWN
By setting interlock function in HA between the first and second relay and then for 3&4, i believe i have to change the script also.
Is it enough to have them interlocked, or a change in yaml configuration would be the solution.
Example:
relay 1 ON relay 2 OFF relay3 OFF relay 4 OFF
relay 1 OFF relay 2 ON relay 3 OFF relay 4 OFF
relay 1 OFF relay 2 OFF relay 3 ON relay 4 OFF
relay 1 OFF relay 2 OFF relay 3 OFF relay 4 ON
.hanks for support
take a photo of your motor, need to understand your moter wire define firstly.
