08-06-2021, 07:43 AM
Thank you again for your invaluable help in configuring and testing your Kincony PLCs !
You will find attached the photos of the PLC arrangements and the wiring diagram of the probes connected to the KC868-COLB PLC.
As you know, kincony PLCs can only supply 500ma in 12Volts to the power supply output connectors used to power an outdoor sensor.
We cannot directly connect and supply the 3 measurement probes on the KC868-COLB PLC, we must supply the 2 remaining probes by a dedicated 220V to 12volts 2 ampere converter.
As we need to feed 3 probes:
Description of how these 3 probes are connected to the KC868-COLB PLC :
Can you help us to correctly configure these 3 probes in the interface of your Kyncony SBC application?
What does the value: coefficient correspond to in the property of the analog measuring probe?
What must be specified for the coefficient value of the temperature probe in A1 + in green color?
What must be specified for the coefficient value of the humidity probe in A2 + colored yellow?
What should be specified for the coefficient value of the green A3 + nitrate probe?
Are the values entered correctly for the nitrate probe for the values minimum value = 0; maximum value = 500; unit = N; coefficient = 100 ?
Why in the dashboard of the Kincony SBC application, the digital probe which measures the wind and the lighting level does not display any of the 2 values and remains in gray for the 01 # button (see screenshot attached) ?
Is the connection of the brown wire on the KC868-COLB PLC to the D1 + connector correct?
Do you have to connect another wire, for example the black connector wire of the digital probe which measures the wind and the light level?
This black wire today is not connected to the PLC. Should it be connected? If so, which connector should we do it?
Looking forward to your response I wish you a good day,
Best regards IOTHDF member,
- a wind speed and outdoor light measurement probe (supplied directly by the power connectors of the KC868-COLB PLC, see attached photo Blue cable for – and white cable for +)
- a soil humidity and temperature measurement probe (supplied directly by an energy converter 220V to 12 volts 2 amps)
- a nitrate rate measurement probe (supplied directly by the same 220V to 12 volt 2 ampere energy converter).
- a wind speed and exterior light measurement probe (connected to the digital connector D1 + by the brown connector cable, see attached photo)
- a soil humidity and temperature measurement probe (connected to the analog connector A1 + by the green cable; connected to the analog connector A2 + by the yellow cable)
- a nitrate rate measurement probe (connected to the A3 + analog connector by the green cable).
