Momentary Switch
I am looking for controlling two channel relays where it moves from NO to Closed and returns back to NO after 1 second. Which model is recommended and which protocol it supports?
you can use KC868-A2 , it's ok for your requirements. support HTTP, MQTT, TCP command and Modbus protocol with RS485.
(12-19-2023, 06:46 AM)admin Wrote: you can use KC868-A2 , it's ok for your requirements. support HTTP, MQTT, TCP command and Modbus protocol with RS485.
Does the time control will be in the code ? or on the module by default?
if you download KCS firmware, it already have timer function.
here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
