12-24-2023, 01:47 PM
Good morning ! I recently purchased the KC868-A32 card. My question is: can Kincony KCS and Home Assistant be used together? Thanks for your help.
KC868-A32
12-25-2023, 12:08 AM
sure. you can download KCS firmware firstly , then integrate to home assistant by MQTT.
12-25-2023, 08:26 AM
Thank you very much for your quick response
12-29-2023, 09:55 AM
12-29-2023, 12:13 PM
this is sample config yaml: https://www.kincony.com/forum/showthread.php?tid=3274
12-29-2023, 02:29 PM
(12-29-2023, 12:13 PM)admin Wrote: this is sample config yaml: https://www.kincony.com/forum/showthread.php?tid=3274I have a KC868-A32 card. Do you have the yaml file? THANKS
12-29-2023, 11:20 PM
here is A32 integrate to home assistant by ESPHome's yaml: https://www.kincony.com/forum/showthread.php?tid=1772
we suggest use esphome directly, not need to use KCS.
05-04-2024, 12:42 PM
Hello ! With KC868-A32 I would like to invert the state of the inputs to be ok with the logic state in Home Assistant?
THANKS
05-04-2024, 11:47 PM
if you config by ESPHome, just add "inverted" for INPUT option in yaml file.
05-05-2024, 05:49 AM
Users browsing this thread: |
2 Guest(s) |
